Well, I've got mine connected to a Samsung TV, and I get the message. Maybe Samsung's DVD division will blame Samsung's TV division?antilles said:Alan,
I've got the dvd player connected to my Sherwood amp for all round DD-EX and DTS-ES goodness...still get the message....
I rang Samsung today and they said that the fault lies with the TV!
So, i'll probably have to contact Sony to get their response to the question, "Why does your HDMI TV not support HDMI audio?"
It's all getting a bit silly innit?
Rich
go into the dvd players settings and change the audio from bitstream to PCM, this will stop the error message.antilles said:Alan,
Rich
lol...yes most probably.clockworks said:Well, I've got mine connected to a Samsung TV, and I get the message. Maybe Samsung's DVD division will blame Samsung's TV division?
Samsung is wrong. It's not the TV's fault. It does support HDMI audio if you change it to PCM in the DVD-player. But the TV doesn't of course support 5.1-audio which you are sending it if you have enabled bitstream, and that's why you get the error-message. But then again, you want to have it as bitstream since you have an external amplifier.antilles said:Alan,
Rich
There is no technical reason for this not to work automatically if they coded it that way. My Panasonic S97 is set to output bitstream but it detects the HDMI audio connection only supports PCM and automatically switches to PCM for that connection. This is confirmed via the player's "HDMI Status" screen.ZaforZ said:They should make a player where you can choose the audio settings separately for the HDMI and optical outputs.
