my v+ box wont save hdmi settings am trying to watch galopogas on
on demand it says switch your settings to hdmi which i have tried but the setting just go back to the default settings.
Any help would be welcome
I'm assuming you have a scart lead connecting tv to V+ box?
If so, I had the same problem and this worked for me.......
Plug your hdmi cable from v+ box to tv, Select from your V+ remote the HDMI setting (either 720 or 1080) then once selected the V+ box will search for the HDMI settings, as soon as starts to search whip the scart lead out from your telly. Hope this works.
right plug in your scarts and hdmi lead make sure you plug it into the right one ...i have 3 ..so you need to plug it into the EXT that you get your V+ picture on....and make sure you get a picture on V+
got to home
setting no 8
change display 4
then change to HI DEF
THEN 720 WIDE
audio HI DEF off
PRESS OK ............it should say searching for picture then ask you to save if not just save anyway by pressing the TEXT BUTTON
this will save your setting ....if you want them back again just repeat in reverse
