HDMI Requirements for the future
Discussion in 'TAG McLaren Audio Owners' Forum' started by scarty16, Dec 23, 2004.
  1. scarty16
    scarty16
    Jul 1, 2003
    1,355
    +295
    I was think about the upgrade options for my AV32R and this got me onto the subject of HDMI v1.1
    I think that I am going to need at least 5 HDMI connections
    1. Sky Hi-def
    2. DVD (std def)
    3. Freeview
    4. PS3/XBOX2/Revolutions
    5. DVD (Hi Def)
    I could even make a case for my CD as well.
    Hmm think I may have to wait for this one.
    Happy Xmas
    Roll On CES
    Simon
  2. jbm007
    jbm007
    I believe HDMI 1.1 does not fully support audio at this time. And everything but your HD stuff will not need HDMI. HDMI is a marketing ploy to get people to upgrade to something 90% don't need. If you are using 720p to 1080p and have dvi output; great use HDMI. DVI and digital coax,accomplises the same thing. Your Sky def and dvd if they have a digital output will work with HDMI. The whole pitch to HDMI is to provide a form of copy protection that cannot be done as well in analog format. We are like lemmings being driven into a net. No clue what we want; but if its the best we want it. Just what I need a bunch of new expesive cable. Yea it eliminates extra cables; but don't get sucked in to buying because its the latest and greatest. We will all get there soon enough, and Hollywood will be there as well. With a digital lock.
  3. AndrewH13
    AndrewH13
    Jan 5, 2004
    16,425
    Southend, Essex
    +6,881
    HDMI is needed for Sky's proposed high definition service as they have announced it wont be output without copy protection.
    "However, it was when discussing how the HD signal would be delivered from the Sky decoder box to a projector/plasma TV/LCD TV that the bombshell emerged, as Sky stated that the vast majority of HDTV programming will only be viewable if carried via HDMI or DVI connections that support the HDCP digital rights protection system. In other words, if your projector or flat panel screen only has component video inputs or an HDMI/DVI jack NOT compatible with the HDCP system, it will not show the majority of Sky’s HD services."
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Hi Andrew.
    I wouldn't worry much mate...... Devices already exist that take an HDMI or DVI HDCP signal and output DVI without HDCP..... I'd also wager that an HD sky box would have component/RGB outputs as well otherwsie it will have a very small market. People get carried away that HDMI is the best picture but at the end of the day it is just cheaper to impliment properly and copy protection is just paranoid people making things more complicated....
  5. mailaht
    mailaht
    Mar 17, 2003
    39
    London
    Another thing to keep in mind about HDMI is that it supports (to my understanding) presently only 24 bit colour depth. While 16 million colours sounds a lot, 24 bit means only 8 bit = 256 shades per colour channel. In dark scenes where the colour spectrum is heavy on one channel (e.g. dark blue or green like in underwater scenes, etc.), you still get colour-patching with 8 bit video. Which is one of the reasons why most new projector models including my cheap and cheerful Z3 support 10-bit video processing.
  6. PhilB1234
    PhilB1234
    Hi Graham, I didn't know this was possible. Could you give me an idea where they might be found/someone could learn more? Purely so I can avoid such awful information, as I love and respect HDCP with all my heart. ;-)
  7. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Hi Phil.
    There is "licencing" and then there is "Licencing", it appears that HDMI/DVI HDCP chipsets do have an "enable/disable" option that may or may not be implimented in a particular device (scalers seem the natural place), of course it would be well hidden in a service menu or similar. Later generations of chip sets may have this very useful feature removed but as I own a bit of kit that has this "feature" and have done for well over a year now it is most useful with displays that came out before HDCP became an issue..... Don't ask the name of the bit of kit as it would be unwise for me to comment further and spoil things for the future..... Besides every copy protection method that comes out normally has a way round it released well before it becomes mainstream, which naturally makes me wonder why they bother.....
    Like I said Paranoia rules......
  8. Yps
    Yps
    Jun 10, 2004
    5
  9. Audionyx
    Audionyx
    Dec 10, 2002
    678
    East Yorkie Porky
    +25
    As I understand it, HDMI also supports YUV at 8,10,12 bit depths
    HTH
    Darren
