HDMI Repeater and ARC Issue
s1xtyn1n3
I have just bought a KSRplayer HDMI Repeater as I was having HDCP issues with my 20m cable running from my Sony STR-DN1040 amp to my Sony 55XD9305 TV.
2160P 3D 4K HDMI Signal Repeater Extender Booster Adapter Over Signal HDTV 60m--Spy Bug Cell TV Video Audio Electronics & Gadgets
The repeater is at the TV end of the cable and immediately fixed issues such as having no picture with blurays. However, I now appear to get no sound from the TV via ARC anymore. I am definitely using the right HDMI port on the TV and having looked closer at the details of the repeater, nowhere does it mention ARC.... Can I assume this is what is breaking ARC and if so, can anyone recommend a repeater that supports HDMI 2.0a, HDCP2.2 and ARC?
THX1138UK
I know this a very old thread, but I’ve recently hit exactly the same. I’ve tried to completely different types of HDMI Repeater (One passive and one active with a 5v power input).
They both stop sound being sent from the TV via HDMI ARC to my AVR.
Looks like this is a common problem, but seems to be very little information on the topic.
Regards,
James.
Joe Fernand
AVForums Sponsor
4K UHD with HDR capable Extender devices with ARC support are pretty specialised - the lower cost units will offer support for ARC to Optical Out and a few units will support ARC 'passthru' via HDMI on a dedicated HDMI Audio Output.
ARC to Optical support - HDfury Integral² - The Media Factory
ARC HDMI Passthru support - https://tmfsolutions.co.uk/product/hdfury-vertex²/
If your TV is close to your AVR it may be simpler/less costly to use the TV Optical Out to the AVR!
Replacing your TV to AVR HDMI cable is another option - if that is practical for you.
Joe
THX1138UK
Joe
Joe,
Thanks for the links to other HDMI repeaters, and for the information provided.
I do have an Optical (Toslink) cable installed. It will pass Dolby Digital from the TV to my AVR, but not Dolby Atmos.
I’m currently using a high quality 5 metre HDMI cable (Profigold), purchased in 2012. It’ll do everything perfectly up to and including 2160p 60Hz, 12 bit HDR at 4:2:0, but 4:2:2 introduces red sparkles.
I can force 4:2:0 from my Oppo 203 and XBOX One X. ‘Billy Lynn’s Long Halftime Walk’ is the only disc where there is a problem and this is fixed by forcing 4:2:0.
So it’s really only an issue with my Amazon FireTV stick, because NetFlix is always 60Hz, and Dolby Vision pushes it over the edge - but seeing as I can use the NetFlix on the TV (which works perfectly), it’s just me been a perfectionist!
I’ve already purchased a UGreen 5 metre HDMI fibre hybrid cable, but it will be months before I can get it installed - my cables are buried in the wall, and it’s not going to be a quick or easy job to redo it all.
I though the HDMI repeater may have been a quick fix, but I’ll wait until I get the new cable installed.
Regards,
James.
Joe Fernand
AVForums Sponsor
Try and install your next cable in a conduit.
Are you able to test that ARC works with the new cable?
Joe
THX1138UK
Joe
Joe,
Due to the corners the cable has to go around (there a fireplace in the way), it's very difficult to pull, even in a conduit. However, the new replacement hybrid cable is much thinner, so might work a little better.
Yes, I have the cable and have tested with ARC.
I was going to buy a Ugreen hybrid fibre HDMI cable as I already have a pair of 10 metre cables in my home cinema room (they are excellent), but Ugreen don't do a 5 metre cable, so I bought at 5 metre Atzebe Fibre optic HDMI cable (£37.39 from Amazon). It works perfectly and passes TV audio back to my Denon AVR via ARC. Fully tested it with Dolby Vision / Dolby Atmos, 2160p 60Hz, 12 bit HDR 4:2:2 video - no issues.
Thanks & regards,
James.
Similar threads
