HDMI over Ethernet (CAT Cable)
kalel786
Hi everyone,
This is my first post.
I needed help and didn't know where to go.
So basically, my computer is in my room, the TV is downstairs, about 40-50 meters away. There's already a cat 5e cable that's wired and nailed into place, but I wouldn't mind redoing it if I need to.
I want 1080p/HD 5.1 audio over ethernet. Could someone point me towards a product that will help me achieve my goal?
This looks to be what I'm looking for.
Labgear High Speed HDMI 1.4 3D Over Ethernet Lan Network Cable Extender 50m | eBay
What kind of extender am I looking for? A lot of the listings don't specify if they're compatible with 5.1.
Do I get any 1.4 3D one? What kind of extender do I need?
I'm assuming I'm going to need 2 ethernet cables. Are there any cables that are like 2 at the end, and twist into one? So it would look like 1 wire going down and not two? Does a cable like this exist?
Any help would be appreciated.
andy1249
What exactly are you looking to do here ?
Do you just want to play the content from your computer on your TV?
You want 1080p with 5.1 audio so presumably your going from your PC to a HDMI equipped amp or AV receiver ? Then from your AV receiver to your TV ?
If so , then something like a WDTV live used along with your existing Ethernet cable will do the job fine !
http://www.amazon.co.uk/Western-Dig...OKC2/ref=sr_1_1?ie=UTF8&qid=1345531160&sr=8-1
Those HDMI extenders essentially take a live HDMI feed and deliver it to your screen , they use two runs of Ethernet cable to do this , and those two runs of Ethernet cable will not be carrying Ethernet signals , they will be carrying TMDS signals and cannot be used for anything else.
In addition , your PC will be working flat out playing the content along with your TV.
So , if the aim is to get content from your PC to play on your TV , then HDMI extenders is not the ideal solution for you.
kalel786
Western Digital TV Live Streaming Media Player: Amazon.co.uk: Computers & Accessories
Yes, you're correct, I wish to play 1080p with 5.1 audio, going through my av reciever to the TV downstairs. I currently use my ps3, which streams from my pc using ethernet doing the same job as the wdtv you suggested would do.
I want my computer to be over hdmi, because I want XBMC, all file compatibility and the ability to play games on the downstairs tv.
So what I'm looking for is a hdmi over cat extender. There are some extenders that work over a single ethernet cable.
I think I need one that atleast supports 1.3 or 1.4 hdmi, as this should be enough bandwidth for 1080p with 5.1.
andy1249
A pair of extenders will give you a live HDMI feed to your TV , how your going to control it without significant lag for games is another matter.
Most extenders will use two runs of Cat5/6 cable , older models that used 1 run of cable caused a very significant drop in video quality.
Also note that to go from the 19 wires usually used in HDMI to the 16 available over two runs of CAT5/6 cable , the shield connections for the TMDS lines are dropped , so the runs of CAT5/6 must be Shielded to work best.
There are new senders , transmitters that will send over one cable , these come under the term HDMI over IP , and are very expensive indeed , your talking something like £400 to £1000 to do this.
Really , for what you want to do , and to do it properly , you would be talking about a purpose built HTPC as part of your Hi Fi rack.
If the games requirement were dropped , there are now plenty of Streamers that will run XBMC and Plex.
kalel786
I was just about to buy this
Cablesson HDelity HDMI 3D Extender Single Cat5/6 (Bi-Directional IR) HDMI 1.4 | eBay
but stopped when I saw your message.
Looks to do everything I need. 1080p upto 50m with true hd 5.1 sound over a single cat6 cable. So this wouldn't work? I'd rather not buy another streamer to be honest, that's the last option I would choose.
Thanks for your help btw, you've been really helpful, I appreciete it.
andy1249
Those single Cat5/6 extenders drop the quality by a huge amount. I wouldnt bother , it will work , but you wont be happy with it.
A pair of extenders using two runs is best. If the cable you already have installed is UTP your going to have to replace it , otherwise you will struggle to get 1080p over it , they must be shielded or STP type and both must run in an unbroken line from Sender to receiver , remember these units do not send ethernet compatible signals , you cannot connect through routers or switches.
About gaming , how are you going to control it ? Just out of interest !
Your selling short the new streamer option if gaming is not a priority, the PS3 was left behind years ago in terms of file compatibility , for example , you will struggle to find anything the WDTV cannot play.
kalel786
Ahh :-(
Does wdtv have xbmc?
I want a streamer that works with xbmc perfectly if I get one.
Could you show me which product has two runs, and can provide 50m 1080p with 5.1 dts over ethernet?
I can't decide if I should get a streamer or Hdmi over cat6.
What streamer should I get if I do get one? I want a decent one, upto £150 i'd be willing to pay for it, the same amount I would of spent on the hdmi extender?
Joe Fernand
AVForums Sponsor
If you go the HDMI over Twisted pair route you are pushing your cable to the limit at 50m with a 'conventional' Dual CAT solution - though the hardware cost makes it attractive, Media Factory - Octava HDCATIR, HDMI + IR over CAT5 or CAT6 Extender
If your budget allows you may want/have to consider the option of HDMI over HDBaseT - these can deliver 1080p, 5.1 audio, IR, 10/100 Ethernet and RS232 out to 100m on a single piece of CAT6; Media Factory - Octava HDCATS-100, HDBaseT HDMI + Ethernet over single CAT5 Extender with RS232 and IR Passthru
As Andy suggests a streamer may be a better solution for you if you can find one which meets your requirements - there is a separate Forum on AVF for streamer's.
Joe
ChuckMountain
Use a HD base t transmitter and receiver you should have no loss of quality and minimal lag.
Also need to send control signals to PC, could use USB over cat a well
