ste1010
Established Member
Apologies for asking a common question, I have read lost of previous threads but still have some questions.
I am looking at wall mounting a 43" TV in a Kitchen/Diner which will be fed from a Sky HD box.
I have multi room but plan to have both Sky boxes in the living room. this will allow the multi room to feed the kitchen diner via HDMI, and also other bedrooms over existing coax.
After reading up on here it appears that HDBase-T is preferred, but is more expensive, but HDMI over dual CAT5e/6 cables will work.
Due to the spend on kitchen refit and building work new tv, etc etc the budget is limited.
I was looking for a product recommendation to cover the following
1-Cable Run will be 10-12m outside so will use Outdoor spec cable (solid strand copper, not CCA)
2-Looking for Power over cable with power supply at remote end only.
3-IR Feed for remote control
4-Max cost £100 for tx/rx (Cable is already covered)
I was looking at a Neet® - HDMI Extender over Cat6 / Cat5e / 30m ** WITH IR CONTROL FUNCTION from Amazon at around £30 plus another 15 for the remote extenders.
Can anyone recommend this set up, or advise an alternative product.
Steve
Steve
