Chocky851
Hope somebody can help
I have a media server that is outputting HDMI- I need to send the signal over cat5/cat6, we have tried with some prosignal HDMI over cat5/6 extenders but the media server will not display out on boot up, if we use an HDMI lead it works. if we then swap the HDMI lead once booted to the cat6 lead it all works fine, the media servers has to shut down every night hence the issue as there unit can not stay turned on so when turned off again it won't load up the display? any ideas? tried a cheaper cat5 sender and it works?
