HDMI or DVI or VGA: Which gives best PQ?
Discussion in 'Desktop & Laptop Computers Forum' started by Dadslo, Feb 3, 2009.
  1. Dadslo
    Dadslo
    Jul 19, 2007
    533
    Aylesbury
    +71
    I recently bought my daughter a laptop which had an HDMI out connection.
    She will be connecting to a 22" monitor.
    In terms of best piicture quality, which connection is best HDMI, then DVI, then VGA?
    Or will they all do the same job...!!!
    Cheers - Kevin.
  2. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    For Picture HDMI and DVI are pin for pin compatible , so regardless of the cable the same picture signal will reach the monitor , so they are exactly the same.
    Depending on whether the monitor has built in speakers , HDMI might be better because that can also do sound whereas DVI cannot.
    VGA is analog , and uses a different electronics chain altogether , its still a very high quality signal and should be just as good as the other two in most cases , but because analog is subject to noise , and digital is largely immune I would go with the HDMI or the DVI.
    For both DVI and VGA you need extra cables for sound ( thats assuming the 22 inch monitor has speakers , if not then you need to run extra sound cables anyway )
  3. peackshelb
    peackshelb
    Nov 18, 2007
    23
    I'd just add one note to andy1249's post:
    The audio transmitted over HDMI is a digital audio signal.
    If a laptop doesn't have a separate digital audio output jack, then sending the audio out over HDMI can often be the only way to get a clean audio signal. Many laptops' analogue audio outputs (eg standard headphone jacks) are a little noisy and their internal speakers are usually an option of last resort.
    HTH :)
