Harkon321
Is this a handshake issue?
When switching sources I'm getting audio but no image from the projector. The mirrored HDMI from the second output to the TV has no issue. The cable from AVR to projector is 12.5m but it's a good quality cable supplied by Allan at Ideal.
It doesn't happen that often but I've had it twice this week. Turning the AVR on and off usually solves it, if not have to restart projector and this sorts it. (Annoying as screen is in 12v trigger)
I do have Cat 5 cable run parallel to the HDMI. Is it worth trying running it over cat5 instead?
Any downside to this? Presume I'd need some sort of converter each end?
