HDMI Module
Discussion in 'Plasma TVs Forum' started by dniven2002, Apr 17, 2007.
  1. dniven2002
    dniven2002
    I have a panasonnic TH-42PWD8 is it worth while getting the HDMI card and using it for viewing, will it make big diference to the picture?
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,529
    Norwich
    +986
    Depends what you are comparing it to. If you are usning composite it will make loads of difference, if you are using component it won't make any difference at all.
    :smashin:
  3. dniven2002
    dniven2002
    Using S-Video from sky plus box at the moment
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,529
    Norwich
    +986
    What are you planning on plugging into the hdmi??
  5. dniven2002
    dniven2002
    maybe sky HD?
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,529
    Norwich
    +986
    To be honest componebt into the vga socket gives just as good results.
    Maybe grab an hdmi blade if one comes up cheap at some point??
  7. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Short term , a jstech SCART-VGA might be worth a look, got to be better than Sky's s-video output.
