HDMI modulator to AV amp andprojector ?
malsat
I am put sky through an HDMI modulator into a distribution amp then to all rooms,
this is fine and TV's show HD pictures,
But how do I then get it back to HDMI to go into Amp and projector in cinema room ?
Do I need to go into a freeview box first then out ?
Old set up was sky analog into VHS recorder then HDMI out into amp
thanks
mal
malsat
I want to use existing coax to send HD digital signal to that room can't do new wire.
I know what a freeveiw box is and it can scan the channel from HDMI modulator I was thinking,
Thanks for your clever answer
JayCee
Your use of “how do I then get it back to HDMI” was confusing.
I (wrongly) assumed your Sky box was in the cinema room and you couldn’t use the HDMI out as it was being used to feed the HDMI modulator hence my suggestion of a switch.
If you'd asked “how can I convert the incoming RF to an HDMI output to feed my projector” then put forward your idea of using the Freeview box things would have become clearer and I would have said yes, that will probably work.
grahamlthompson
Tune a Freeview-HD device to the single DVB-T HD mux on the coax cable. Connect the Freeview-HD box HDMI out to the projector. If the device is a Freeview-HD PVR you can also record and live pause the content.
Podcast: Trinnov Room Optimiser: A full explanation of Trinnov and its room optimiser technology
