HDMI micro for HTPC
Discussion in 'Cables & Switches' started by noodlehead08, Feb 23, 2013.
  1. noodlehead08
    noodlehead08
    May 15, 2011
    2
    Hello, just a quick one, if I was to get hold of a micro HDMI cable and then used a micro to full size hdmi adapter/converter would this cable then be able to be used between a HTPC and TV? I need to put cable through a wall and with the micro plug being a lot smaller this mean that the hole I need to make in the wall and conduit used for the run would be smaller. Any help would be much appreciated. Cheers.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,616
    The Borders
    +3,501
    Better to drill a suitable sized hole and avoid any potential for the Standard > Micro > Micro to Standard connections becoming a problem.
    Joe
  3. noodlehead08
    noodlehead08
    May 15, 2011
    2
    Hi, thanks for the advice, the cable I was looking at was full size one end and micro the other. Asked the eBay seller the same question and they said it simply wouldn't work? Guess I'll look for a bigger drill bit!!
