HDMI 'loosing' connection to PC after source change
hallabusa
My PC is connected to my 435XDE via HDMI, however when I change from HDMI to another source, I 'loose' the PC connection- the Pc is still active but my TV doesn't 'see' the PC. Even turning on/off the TV makes no difference, it seems as though the only time it'll see the Pc is on boot-up.
I've got a Radeon 9800Pro card running the latest Catalyst center which allows you to easily change the screen resolution to a custom 'non-standard' size, ideal for the 435.
Anybody have any ideas?
Cheers.
Pootle
Sounds like the same problem I have, you have to go back a few driver versions to fix it - I think 5.6 is OK. ATI have taken a lot of convinving that they have a problem. but seem to now admit it, so may be fixed soon. :thumbsdow
