hdmi lead
Discussion in 'Cables & Switches' started by stevey27, Jan 16, 2008.
  1. stevey27
    stevey27
    Jan 13, 2007
    147
    +5
    if an hdmi lead is v1.3 compatible will it also support 1080p
    cheers steve
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    Yes, but you don't need to have a '1.3' lead to support 1080p.
    Do not spend a fortune on short HDMI cables, actually don't spend a fortune on long ones either as it isn't necessary.
    If you are planning to spend over £20 on an HDMI cable ask for advice on the specific purchase here first.
  3. stevey27
    stevey27
    Jan 13, 2007
    147
    +5
  4. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    OK, no experience with that particular brand but the price is not excessive and they claim 1.3 and 1080p so if it doesn't work should be easy to deal with them.
    There are cheaper places around but not much cheaper and not many of them do white cables if that is important to you.
  5. stevey27
    stevey27
    Jan 13, 2007
    147
    +5
    ordered one so i'll see what its like, needed something abit longer than the qed one i have and one i can leave in the ceiling sholud i decide to move so this fit the bill
    cheers
