Hello All. First time post in the community and would value some expert advice. Just upgraded from a Pioneer VSX 2021 to a Denon X3300w. Existing 7.1 setup with monitor audio speakers and a velodyne sub. BT UHD box, Panasonic plasma TV. Epson TW6100 projector. Grandview screen. PS4 Pro. All played nicely together.
Had a professional installer in yesterday he upgraded interconnects to hdmi cables that support latest a protocols, digital optical from the TV to the amp and some speaker work (they are in wall). Everything went smoothly up to the final step of setting up the Denon.
Audessey speaker setup fine. Can see the Denon OSD fine. Then started to set up the inputs. TV got audio, no video. same for the PS4 and projector. Exiting the setup we get an error saying get a message saying content cant be displayed because my tv doesnt support HDCP. Ok I know this.
Did the Denon firmware update. PS4 firmware up to date. Not done the plasma yet. It's 4 years old. 1080p max display.
Did the root cause stuff. Swaped all the cables. Same issues. Direct connect the TV/projector to PS4/BT box, no issue. Reconnected everthing through the amp.
My installer tried a blustream HDMI manager on the Denon outputs and set it to HDMI 1.3, 7.1 - hey presto we get a picture and audio together. Magic.
After reading various threads (including on BT TV and PS4) I'm near the conclusion that it's a handshake/output/HDCP issue. The Denon by default is pushing out HDMI with HDCP 2.2 as default and not autoswitching to match the input/output devices. My TV does not like and there's a similar issue as to why my PS4 can't get through to the amp to the output. Spookily PS4 picture did not get through, then it worked, then it stopped working again. There appears to be a workaround for the PS4 to switch of HDCP 2.2. Not tried that yet. Finally, and this is baffling, plugged in my Amazon fire stick (last generation) to the front HDMI, works first time! So the amp likes the fire stick and happily sends the signal to the TV. Not validated if the from HDMI port is it is not 2.2 compliant.
Apologies for war and peace. Before I send the one day old amp back for something else that does not have the issues, would appreciate some guidance. All I want to do is watch movies, TV and listen to music easily.
Thanks,
Brian.
Thanks,
Brian.
