Hi there.
I would really appreciate some advice on a problem i'm having with a Philips 26PF5521D tele.
I've had this for a good few years now and only ever needed to use one of the two HDMI slots.
I now need to use the second slot but this is where I'm having issues.
Originally I had a freesat box plugged into HDMI 2 and this worked no problem at all.
I now have an xbox 360 with HDMI that I have plugged into HDMI 1. FOr some reason though, it doesn't recognise it as being HDMI, and my XBox thinks its DVI connection.
I've swapped them around when the xbox is in slot 2, it works correctly, and the freesat box doesn't work in HDMI slot 1.
So I'm pretty sure theres something not right with HDMI 1.
DOes anyone know if there is a setting or something that I need to do to sort it and make it act as a HDMI and not DVI?
Thank you very much in advance,
Craig
Craig
