HDMI - International Standard?
Mike246
I would appreciate some tech advice from you guys.
I have a UK Toshiba TV which is rated at 1080i and will accept 720p.
I wish to buy a Canon video camera (Model HG10) in the US while on holiday. Is this going to work with the TV or are there any frame rate/other issues?
I am an ex BBC design engineer so I know all about PAL/NTSC standards, but this one has got me beat!
Joe Fernand
AVForums Sponsor
Hello Mike256
What you have to confirm is what Frame rate the 720p/1080i signal is running at - 50Hz/60Hz or some oddity of the Camcorder world.
Then you need to confirm your Display supports that signal format on HDMI.
Also ensure you know if the Camcorder uses a 'standard' full size HDMI Output connector or one of the Mini HDMI connectors - if its the Mini ensure you get a 'Mini to Standard' cable or adapter as they are still thin on the ground over here.
Joe
Mike246
Joe,
Thanks for that.
The Canon camera is 1080i with a 60 Hz refresh rate (US spec). I guess the nub issue is whether the scaler in the Toshiba television can work with this.
Joe Fernand
AVForums Sponsor
If it carries the 'HD Ready' Logo it ought to!
Joe
Mike246
Joe,
You raise an interesting point and I thank you.
I checked with the HD Ready spec and as you state, 1080i at 60 Hz is included.
My Toshiba TV is HD Ready so it's a done deal. Just as a cross-check I've e-mailed the nice people at Toshiba.
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
