HDMI Help Urgent!
Discussion in 'Cables & Switches' started by Henry, Nov 4, 2004.
  1. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Help! Just connected up an Arcam DV79 to the media box of my Pioneer 50HDE with an HDMI cable and....Nothing! :suicide:
    According to the back of the media box this should be input 3. But you press input 3 on the remote and.....nothing.
    I've connected the Arcam to the media box with a Scart lead and that works fine. I've then set the output priority to HDMI in the setup menu on the Arcam DV79 but still nothing.
    I've :rtfm: but am in desperate need of help. :lease: :lease: :lease:
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    You also need to set input 3 on the plasma to HDMI...
  3. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Simon
    Cheers for the very prompt reply. How do you do that?
  4. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Press Home Menu, Option > Enter, HDMI Input > Enter, Setting > Enter and Enable > Enter... I think the Arcam can output 576i and 576p, worth trying both options...
