hdmi from sky hd
woodmaster
When the hd box arrives will it replace my current box in other words will it then pipe all other SD channels through its HDMI output or will they have to be sent via scart.
Starburst
Unknown:)
You would assume though that all the non HD channels can be fed to the TV via HDMI either in standard def or upscaled by the hardware (if possible).
You will be able to feed a second TV with standard def which means being able to feed a VCR/DVDR as well which you would expect to be via RGB scart.
