King_Louie
Established Member
Hi all. Hope someone may be able to help. I have done many searches on this topic but Im still a little confused. I am looking to do the following:
Onkyo Amp hdmi output into HDMI switch/splitter input. I then want to feed this signal to a 1080p projector and a 720p lcd. I only want to use one display at a time. I will have to check but I dont believe the lcd supports 24hz whereas the projector does. None of the cable lengths will exceed 5m. Obviously sound will not be an issue as the amp will take care of this.
I am sure there must be affordable item that I can switch to the ouput I want, turn the amp and ps3 on. Can anyone point me in the right direction? Thanks in advance.
