HDMI for 20mm conduit ????
Discussion in 'Cables & Switches' started by Ricky22buk, Dec 18, 2006.
  1. Ricky22buk
    Ricky22buk
    Oct 16, 2005
    103
    As the title states guys, is it possible to buy good high end quality HDMI cable which will fit down 20mm conduit ? Just measured my HDMI lead which came with my Sky HD box and it reads 19.8mm, so it therefore wont go down 20mm conduit. All my house is wired in 200mm and it would certainly save me alot of time and hassle if I could buy cables to suit. Any suggestions ???
    Cheers !
  2. Ricky22buk
    Ricky22buk
    Oct 16, 2005
    103
    Surely someone else has had this problem !!!!
    Anyone ????????????
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    1. Go to the shop and see if they have cables with smaller connectors (different manufacturers might use smaller moldings).
    2. See if a HDMI to HDMI-Mini connector cable can be used, together with an adapter from HDMI-Mini back to HDMI.
    3. Buy connectors and cable for a DIY job.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,933
    The Borders
    +3,575
    Hello Ricky22b
    I've looked at about a dozen connectors we have here and they are all 20mm or 20mm+.
    One option is to use CAT5 cable (x2) plus a set of HDMI over CAT5 extenders - see http://www.gefen.com/kvm/product.jsp?prod_id=3872
    Keep in mind the metal pin out shroud on an HDMI plug is 18mm wide - which doesn't leave much room for the body and shield if your looking to find something that's sub 20mm.
    Is the conduit a straight run or with bends?
    Joe
  5. jonny round boy
    jonny round boy
    Oct 25, 2006
    194
    Halifax, West Yorkshire
    +12
    Surely it's a bad idea to run the HDMI cables through the existing conduit with the power cables? Just run them seperately, it'll be a lot easier that trying to feed them through existing.
  6. frank-e-boy
    frank-e-boy
    Sep 25, 2006
    72
    put in bigger conduit? 20mm isnt the only size. get some 25mm or 32mm stuff. I have also seen someone put 40mm wastepipe in the wall. It was on a post in the DIY section I think. Looked like it would do the job easily, involves quite a bit of chasing though.
  7. Alun
    Alun
    Sep 15, 2004
    2,604
    Praying to the God of Wind
    +243
    LOL
    I'd be next door if I chased that deep.
  8. Ricky22buk
    Ricky22buk
    Oct 16, 2005
    103
    Really wanted something that would involve as little hassle as possible. All the rooms are decorated and all the conduits and plugs are left up the wall for plasma's. I know I can retrack, plaster and redecorate but I just didnt want to, that why I asked this question ! The Cat 5 idea Joe is a good one but seems to be an expensive route as I intend to have 3 plasma's around the house. Thanks for that advice though Joe but it seems as I may have to get the hands dirty again and just replace the conduit.
    Joe on another note please dont forget to get back to me with prices on the items I sent you. I'm not in a panic as I'm sure your head is turned for Christmas, but just asking for a return email when you get some free time. Thanks in advance for all advice given and taking the time to reply to my emails.
    Best wishes to you all for both Christmas and the New Year !!!!1
  9. jonny round boy
    jonny round boy
    Oct 25, 2006
    194
    +12
    Yes, that was me!
    If it's in a masonry wall (as mine was) I'd really only recommend that for short runs, but if you were building a new stud wall it'd be really easy to integrate it.
    And yes, it did need quite a bit of chasing, but with an SDS chisel it only took about 20 mins (plus about 2 days to clear up the mess..:( ).
