hdmi extension
Discussion in 'Cables & Switches' started by gtimadman, Jan 6, 2012.
  1. gtimadman
    gtimadman
    Jan 14, 2010
    285
    Ive run a decent hdmi lead from tivo box to tv but now have a new tv and leads to short will extending the hdmi degredate the signal or quality, alas replacing the lead toaly isnt a option
  2. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,676
    +1,575
    Depends how far you are sending the signal. Anything up to 10 metres will be fine on a half decent lead. Beyond this, a powered and equalised cable can be had for £40 or so.
    You don't need to buy a dedicated extension lead. Just buy a cable of the correct length and a joiner.
    The signals are digital, so it will either work or it won't! You won't see any signal degredation as you would in an analogue system.
  3. gtimadman
    gtimadman
    Jan 14, 2010
    285
    cheers extension only be 1m , aw aok so use a back to back hdmi joiner
  4. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
