I have just fitted two HDMI cat6 extenders to send signal from sky+HD box to tv in another room approx 40m apart. I used two extenders supplied by HD connectivity with the optional IR sender. After fitting I got a perfect signal and was able to operate the sky box using the sky remote. So for so good. Unfortunately the tv remote will not work when receiving a signal through the extenders, which I need to do to control the volume or change the input to watch a DVD or use other device plugged into the tv. I have tried removing the IR sender, but this makes no difference to the tv remote. It has been suggested to me that the cause could be IR flooding. Can anyone please explain what this is and the cause and how to rectify.
Mike
Mike
