HDMI Extender Camera Feed Problem
Bandog Studios
Hello All,
I am in the process of testing a Black Magic ATEM mini pro with a camera feed through a Cat6 Ethernet patchbay with Ethernet to HDMI 1.3 extenders (I am within the operating 50m range of the extenders). When I connect the camera directly to the ATEM the feed is fine, but when I connect the camera through the HDMI extenders the feed changes to mostly green with purple highlights. I have tried with both shielded and unshieled Cat6 cable with no difference I have tried the EDID function on the extenders as well to no avail. I have no idea what could be the problem is because when I use the same cables and extenders to send a video signal from the computer to an external monitor the signal is fine, its just when I send a live camera feed from the camera through the cat6 patchbay and extenders that I have the problem. Any ideas are welcome, please and thank you
