HDMI DVI - Laptop to Plasma
Discussion in 'Plasma TVs Forum' started by DrDel, Sep 19, 2005.
  1. DrDel
    DrDel
    Mar 22, 2005
    5
    I just bought a HDMI DVI cable
    I have a Dell XPS2 laptop and a Pioneer PDP 5040
    I plugged the cable into Input 3 of the Pioneer Receiver for the TV and turned on the laptop once connected.
    I hit Input 3 on my remote control and get a blank screen.
    What am I doing wrong ? i am trying to view the laptop on the 50" plasma.
  2. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,799
    Caterham
    +59
    You probably need to activate the second display on the laptop
  3. DrDel
    DrDel
    Mar 22, 2005
    5
    my apologies
    I hit the Function F8 key (labelled CRT/LCD) and nothing happens.. still a black screen.. what gives?
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    The resolution and/or timing the dell is sending are incompatible with HDMI port. It's intended for video signals, and is truly crap with a PC. You'll need powerstrip to get it to function really. You can get a picture at 1280/720 60Hz, but the overscan is so ridiculous you can't see the taskbar, or 1/2 your icons. Give in, use VGA.
  5. DrDel
    DrDel
    Mar 22, 2005
    5
    give in?
    argh!
    based on the advice of people on this forum I went out and bought the HDMI DVI cable because it reportedly looked sweet!!!!!
    now I am hearing to just give up and go VGA! what the fudge??!
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    There are folks who use the HDMI port for this. One guy posted his settings, which made us realise he's forced a resolution something like 1120x690 to get rid of overscan. I can't imagine how this would 'look better' than native on VGA. The thing is simply not PC friendly, and Pioneer never said it was.
  7. a_nicholson
    a_nicholson
    I had the same issues with my 37PV500. I heard read that HDMI was better than VGA, it was just a matter of using powerstip to get the correct resolution. So I bought a DVI->HDMI cable and spent a full day trying to get the correct setting, never found the right setting so gave up. I seem to remeber someone posting some powerstrip settings for a Pio though, might be worth a search.
  8. DrDel
    DrDel
    Mar 22, 2005
    5
  9. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    That's the one, it just gives you the flexibility of different resolutions and refresh rates.
