HDMI -> DVI hookup problems.
Discussion in 'Playstation Forums' started by Theft, Dec 27, 2006.
  1. Theft
    Theft
    So I got the dvi to hdmi cable. hooked it up and kept my component cable hooked up as well and I reset the ps3 to favtory default 480i resolution (ew btw) and it pops up with a screen saying it has detected an hdmi cable and says would i like to use it. I click yes and switch to my dvi video setting on my tv and it flickers a second and stays at a black screen. Any ideas?
    This is my tv btw. http://www.tacp.toshiba.com/televisi...sp?model=57H83
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Were you using component before ? Have you changed the connection option to HDMI in the display settings on the PS3 ?
  3. Theft
    Theft
    Yes I was using component before. But left them hooked up and did the factory reset by holding the power button 5 seconds when turning on the ps3. It said it detected the hdmi and I clicked yes and it goes to a black screen. I switch to my DVI input on my tv and it still a black screen. = /
