HDMI/DVI DVD Player vs. Computer DVI out
Discussion in 'Blu-ray & DVD Players & Recorders' started by mariachi76, Nov 22, 2004.
  1. mariachi76
    mariachi76
    Hi!
    I wonder if on a projector like a Panasonic 700 it is better to use a standalone dvd player (I would buy the Denon 1910) or to assembly a barebone-pc with a Radeon 9600 with DVI and a Software DVD player. Which solution would theoretically and practically give the better image on a Beamer? And Why?
    greetings
    mariachi76
  2. mariachi76
    mariachi76
    Does really nobody know if the dvi-port of a fairly good VGA-Card givse the same quality picture like a fairly good standalone player like the Denon 1910 when viewing on a 1280x720 projector?
    Whats about the differences of VGA-dvi <-> DVD-dvi when upscaling to 1280x720, and progressive scan and deinterlacing and all the other things needed for a good digital picture on the projector?
    In short words: Can anyone explain me if wathcing dvds on a projector from coumputer is as good as from a dvd-player using dvi?
    thanks
    mariachi76
  3. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    more than likly if you use the right DVD software a HTPC can provide stunning home cinema.very important to get a 1:1 pixel map for best results but a HTPC will give the most expensive of DVD players a run for there money.
    just a burden having to boot a pc all the time to watch a movie
    VGA>DVI is analog DVI-i>DVI-i is analog as well but can also transport DVI-D which is digital
  4. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
    I'll let you know mariarchi76 how my Samsung DVD-HD945 (HDMI-HDMI) compares to my ATI Radeon 9800 Pro HTPC (DVI - HDMI) @720P ONCE IT ARRIVES :)
  5. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Ive tried many different PC DVD software but they all looked terrible compared to my DVD player.
    These days however, if you can get propper Hi def software to play Hi def DVDs then maybe yes.
    Newer graphics cards like the 9800 pros and X800's and 6800 should do a good job.
    Hardware isnt the problem though, more finding the right software.
  6. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Are you running ffdshow on your hcpc?
  7. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    6600GT should actually give the best results with TT2 alegedly...
  8. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
    Yes Inzaman, I'm running the latest version of FFDSHOW, which doesn't have the PAL/NTSC Format change issues. I am also using the latest nvidia 1.00.58.
  9. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    It will be interesting to read your opinion on the 945 and the hcpc then as i used to have a 935 which i couldnt get on with. I now have a hcpc running ffdshow and am thrilled with the quality of the image in particular those with decent dvd transfers.
