Having just bought myself a Lumagen HDQ
I need a little info on connections. To start with I'll be using a Denon DVD3910 and a Humax PVR9200. I have a HDMI cable for the 3910 which I think I will need a HDMI/DVI adapter.. For the Humax 9200 and I propose to use my RGB - component convertor to feed a component signal to the HDQ. Or should I just use the composite/s-video connection? I also have a HDMI cable feeding my plasma TV. Would I be right in thinking that with these sources all I need for now would be two HDMI/DVI adapters - one for the 3910 and one for the plasma? If so, any ideas of where i can get them? Thanks for your help
Bob
Bob
