We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
HDMI down composite video cable
Discussion in 'General TV Discussions Forum' started by AMCross, Oct 31, 2017.
  1. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    Anyone have any experience with this
    Have loads of tv’s wired up using quality composite video cable that I would like to convert to hdmi for sky hd
    Can’t replace the existing cables as they are run in the walls
    It’s in a sports bar that won’t be refurbished for another 12 months
    Seem to remember coming across a device that sent hdmi signal down 75ohm cable and then reconverted back to hdmi at tv
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,708
    Redditch
    +4,220
  3. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    thanks
    I used either a atlona or Kramer unit about three years ago down cheap aerial cable and the picture was surprisingly good but cant seem to find either unit
    will check your link
    thanks
  4. dannnielll
    dannnielll
    Sep 16, 2017
    2,279
    113
    ireland
    +953
    When you state composite video cable what exactly do you mean?. Do you have access to its specs? If not you could try as a test... Get one of those older video recorders players with an RF output and feed it into cable. At the other end stick a TV set at the same cannel and see can you get a reasonable picture... A good use for one of those old analogue input TVs and video players. If the image from the video is good to go then you are sorted.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    29,049
    The Borders
    +3,606
    As above it is likely you have RF cable wired around the building - which will terminate in a RF 'aerial' connector rather than an RCA connector (which is used for Composite video).
    Once you confirm what you have it will be easier to suggest some options.
    Joe
    PS Hope you are planning for some decent CAT6 around the property for UHD. Distribution?
