HDMI Connection for Wii
Discussion in 'Cables & Switches' started by TJUK1, May 6, 2007.
  1. TJUK1
    TJUK1
    Does anyone know if I can connect my Wii straight to my HD TV using a single cable from Wii to HDMI port on TV?:confused:
  2. jezzer256
    jezzer256
    Oct 18, 2006
    1,879
    63
    Sussex
    +164
    Well the Wii doesn't have an HDMI output so no.
    Sorry if that's a silly answer but I'm a bit confused!
    Jezzer
  3. recruit
    recruit
    Unfortunately TJUK1 the Wii is not possible of giveing an HD output and the highest quality of connection that can be used is component.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,723
    The Borders
    +3,513
    Hello TJUK1
    Probably best to ask why you want to connect the Wii to the Digital (HDMI) Input on your Display?
    The Wii Outputs an Analogue signal on SCART (RGB+Composite sync) or 3RCA (Component) using proprietary cables - its likely that your HDTV has the required SCART or 3RCA Inputs so no real need to integrate the Wii with the Digital (HDMI) Input on your Display.
    You can employ active conversion to get the Wii (Analogue) signal (Video + Audio) into your Digital (HDMI) socket - though its relatively expensive; see
    http://www.gefen.com/kvm/product.jsp?prod_id=4425
    and
    http://www.gefen.com/kvm/product.jsp?prod_id=4174
    Joe
  5. debrrose
    debrrose
    Nov 24, 2011
    2
  6. Dom101
    Dom101
    Dec 31, 2010
    58
    Kent
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,723
    The Borders
    +3,513
    It may work - over on AVS there is a thread where someone has that unit working on a short direct connection to the TV but not when connected via an HDMI Switch!
    Joe
  8. Dom101
    Dom101
    Dec 31, 2010
    58
    Kent
    It may do. Oh right, have to take a look. Not sure whether you would also need a 3.5 coming from that adapter for the audio as well. Wanting to get my Wii connected soon!!
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,723
    The Borders
    +3,513
    The 3.5mm will be the Audio Input to the Converter - the Converter takes Analogue video + audio (from the Wii) and converts both to the HDMI digital out!
    If you want audio via an Amp rather than the TV you can connect the Wii audio direct to the amp rather than to the Converter.
    Joe
