hdmi/composite prob
Discussion in 'Playstation Forums' started by Ashy, Sep 14, 2007.
  1. Ashy
    Ashy
    Jan 3, 2003
    391
    +14
    ive got my ps3 set to hdmi to use on my plasma, i want to take it upstairs so i can plug it temporarily into my computer monitor and then get it online and grab demos etc.
    prob is i cant set it to composite as when i try on my plasma it basically says its not composite and refreshes back to hdmi.
    when i plug it into my monitor its not set to composite and i get a black screen.
    AAARGH.
    anyone offer any advice please haha!
    thanks in advance,
    Ash
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Connect the PS3 to your monitor and then turn it on. When turning it on keep pressing the on button until you hear two beeps. This should reset the console to the default video output which should be the composite input. Ofcourse you will probably need to do the same thing when connecting it back to your plasma.
  3. Ashy
    Ashy
    Jan 3, 2003
    391
    +14
    thanks mate, sorted it :smashin:
