HDMI>component convertor worth trying?
Discussion in 'Projectors, Screens & Video Processors' started by daws0n, Jun 16, 2015.
  1. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    I am going to built a XBMC/kodi based small htpc for use with a Toshiba 36" 100hz CRT TV. It's an old set but still very good for DVD / SD playback as it accepts 480p signal via component input. Plus, it weighs nearly 80kg so not going anywhere any time soon :)
    Strict input requirement means my options are quite limited and I will need to use an old GPU and large case to output component signal natively.... On the other hand I have an itx i5 board here that has onboard HDMI and is ready to go... Is it worth exploring the possibility of using a convertor to output 720x480 from HDMI to component? What is the PQ like via these boxes?
    Any comments/experiences are much appreciated.
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    First thing I would test is whether the Kodi interface is useable at 480p
  3. daws0n
    daws0n
    Apr 28, 2006
    842
    28
    Gwent
    +27
    No problems at all working well via headless native component output of ati gpu.
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,525
    Kent
    +830
    Then it should work no problems with something like a HDFury2 HDMI-VGA/YUV converter
