hi there,
ive recently installed my freesat+ hd in a cubboard under the stairs, i have used a cyp hd over cat6 extender to reach tv and all has worked fine, problem being when installing my bluray aside the system is unable to produce a 1080p picture, im aware of the addional bandwith required and i am a little disappointed with myself as the cable under floor is only cat5e( since then the carpets been laid) paired with the fact the extender is only for 1080p transmisions up to 15m over cat6, tv is approx 15m away bluray works fine when using 1080i but im afraid this will not be good enough for me haha
So thats my set up and heres where you superstar installers come in
if i was to install a hdmi repeater amplifier at tv position as you would do with a long hdmi lead run would this be enough to rectify the problem? my thinking is yes as the problem is with attenuation over the cat5e cable
any help with this would be muchly appriciated and i welcome any responses
Tom
Tom
