hdmi carrying sound?
Discussion in 'Plasma TVs Forum' started by Barend, Jul 10, 2005.
  1. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Hi all,
    Thinking about buying the new Marantz SR-9600 all singing all dancing rreceiver.
    My DV-9500 has no i-link but it does sport hdmi output.
    The DV-9600 (expected in September) has i link added, but I don't intend to swap just for that option...
    Would it be a viable option to route this through the receiver to my DVDO HD+ scaler, so I can use the hdmi sound in my receiver?
    Will hdmi also support sacd and dvda ?
    Will hdmi transported 6ch audio sound better than analog?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HDMI 1.1 will indeed support digital SACD/DVD-A no way to say if it will sound better but as HDMI is still very new you need to check with your dealer and Marantz if the chipsets in your DV-9500 are capable of SACD/DVD-A over HDMI and that the receiver is also capable the HDMI cables can carry it but early HDMI chipsets were stereo only, multichannel chips have only come on in the last few months
  3. Barend
    Barend
    Apr 12, 2004
    804
    +9
    thanks Hornydragon,
    It's a bit confusing, since I've been reading 1.1 only supports dvd-a but not (yet) sacd.
    Also, unlike i-link it does not seem to be a clocked signal, it appears that's causing jitter, something (they say...) dsd is very suspectible to.
    I may just get the Marantz receiver and see what happens...I'm certainly not going to change my DV-9500 for the DV-9600 just for the i-link capability...
