HDMI card for Panasonic PWD4 Plasma
Discussion in 'Panasonic TVs Forum' started by JiMbOb_74, Jan 2, 2005.
  1. JiMbOb_74
    JiMbOb_74
    Was there ever available a card to enable HDMI on a pana 4 plasma? If so can you still get one.
    I also use the component in on the card...does it replace or add to the inputs?! Any help please!!
    :thumbsup:
  2. Andrew_P_S
    Andrew_P_S
    To my knowledge the first to accept HDMI was the 7 series, and they are not backward compatible.
    ...and even those HDMI boards have a question mark over their compatibility with future European HD broadcasts.
  3. 406lx
    406lx
    Nov 22, 2004
    895
    28
    Nottingham
    +27
    An announcement by Panasonic is rumoured to happen this month regarding HDMI boards
  4. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Where did you read that?
  5. jont
    jont
    Apr 8, 2002
    4,197
    near Aylesbury
    +528
    The only boards available for the 4 series were the component, scart and a dvi ... the dvi isn't hdcp compliant so wouldn't allow a hdmi>dvi converter to be used on hdcp flagged material/devices ...
    But I'm still on the hunt for one to try with my htpc so if you come across one let me know !!
    Jon
  6. 406lx
    406lx
    Nov 22, 2004
    895
    28
    Nottingham
    +27
    A couple of people have mentioned it on this forum, its only a rumour at the moment.
    What PW generation it refers to is not known, anyones guess.
    We will have to wait and see if Panasonic make a statement, if they do bring an updated card for the PW7 out, that will be the clinch for me ordering one
  7. JiMbOb_74
    JiMbOb_74
    Thanks for the replies... what about the dvi card then would that not work? and how much is one or does anybody have a part number so i can search?!
  8. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Same here
