HDMI Cables
Discussion in 'General TV Discussions Forum' started by WeSayAJ, Apr 24, 2007.
  1. WeSayAJ
    WeSayAJ
    Apr 23, 2007
    16
  2. NicolasB
    NicolasB
    Oct 3, 2002
    6,686
    137
    Emily's Shop
    +1,068
    For a cable 5m long or less, all HDMI cables produce identical results (unless the plug actually falls off, or something). As lengths increase beyond 5m, they can start to be a little bit more touchy.
  3. asnpcwiz
    asnpcwiz
    When it comes to these cables it really doesn't matter. Although you may want to consider a cable that has a thick jacket if it's going behind furniture or in wall. You may want to get something nice and strong. Monoprice has great cables for cheap. I particularly like their 24AWG with Net Jacket. A 6 foot cable will run you $18.
    http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10240&style=
  4. WeSayAJ
    WeSayAJ
    Apr 23, 2007
    16
    Awesome help thanks guys!
  5. ginger123456
    ginger123456
    Jan 24, 2006
    80
    11
    gosport
    +8
    Hi Wesayaj, for a 2m length get the cheapest, it makes no difference whatsoever, its all digital it either works or it doesnt.
    ginger123456
