HDMI Cables - Advice needed
pilgrimchris
Have just ordered a Panny LCD 32lxd500 together with the toshiba s350e and want to connect the two via HDMI. What advice would you give on buying an HDMI cable (some of them seem incredibly expensive).
many thanks :thumbsup:
Joe Fernand
AVForums Sponsor
pilgrimchris
Some folk will tell you they are all the same and some will tell you the more expensive ones are best!
For short runs (up to 5m) you can achieve excellent results with the relatively low cost Molex cables - though even over a short run if your running higher resolution signals (720P and 1080i) its well worth considering something using a heavier cable.
See http://www.bettercables.com/hdmicables.html
Best regards
Joe
