HDMI Cable
Discussion in 'Cables & Switches' started by rockdg, Jan 23, 2008.
  1. rockdg
    rockdg
    May 3, 2007
    62
    I am not ready to go in quickly and purchase a HD or Blue-Ray DVD player yet. I was going try an up-scaling DVD player first until I was priced £45.00 to buy an HDMI cable from Currys. Does anyone experienced in this field think that the HDMI cables from CPC priced @ £5 can do the same job. I also need to know if up-scale needs a cable that can handle greater than 5Gbps. Any advice is appreciated. For the record is was going to try the Phillips DVD player from Asda priced at £29.99
  2. gblades
    gblades
    Dec 27, 2007
    396
    Bracknell, UK
    +51
    There are plenty of topics about this in the cables section but basically any cable will work fine.
    If the cable is long (say over 5M) then a better one might be a good idea.
    Also if it is for a console where the cable is going to be moved around and unplugged then a better quality one might be a good idea.
    For normal use a £5 cable should be fine.
  3. Ambulance Andy
    Ambulance Andy
    Feb 26, 2007
    195
    West Sussex
    +6
    I can whole heartedly recommend www.markgrantcables.co.uk Top quality cable for less than £20.00
    :thumbsup:
  4. Peopleselbowpad
    Peopleselbowpad
    Jan 13, 2007
    870
    Middlesbrough
    +53
    Second for Mark Grant, superbly constructed solid cable and next day delivery.
  5. machinehead
    machinehead
    Sep 5, 2004
    468
    Greenock
    +15
    amazon sell a brilliant cable for£2.99.not thin,real good quality.
