HDMI Cable
kenko
Hi Guys
I have just bought a Toshiba HD-E1 DVD player which should get delivered next week for £255.
However, I will need to buy a HDMI cable to go from the HD player to my HD-TV.
Can anyone recommend a decent cable at a cheap price?
Also would I use an optical cable for the sound?
Thanks for any help.
R
royster
You get a hdmi lead in the box with the unit. If you want digital sound you will need a digital audio lead (Toslink type). Hope this helps you.
kenko
Do you reckon the cable will be ok then? Dont really want to spend money if I dont have to.:)
Where's the best place to get a digital audio cable from?
Bit new to all this.
Indiana Jones
Digitial is Digital mate, over a short distance a £5 cable should perform just as well as a £30 cable.
Avi
My amp is a
Sony STR-DB930
so not sure if it does digital sound:confused:
I'm pretty certain this amp has optical/TOS link inputs. You can find these for ~ £10 for a 1m cable. The HDMI cable supplied with the Tosh is fine. You will notice no difference in PQ with a more expensive cable on shorter runs unless there is damage to the connectors or cable itself.
AVI
kenko
Thanks guys thats a great help.
So i need a digital optical cable now then. Hopefully no more than a tenner or something.:)
Indiana Jones
Optical is digital then yeah?
All optical cables are digital?:confused: :suicide:
ISave my self £10.
Yes all optical cables support digital.
By the way you can get a 2m Optical cable for £3.99 so dont go spending £10 lol
TrevorS
As long as the length of the included HDMI cable is adequate, it will be fine -- no need to replace it.
