hdmi cable
maxwan
am i better off putting in a HDMI cable as well as a component cable whilst i have my living room in peices
Joe Fernand
AVForums Sponsor
maxwan
HDMI or DVI - either one makes sense if your system is going to be installed for the next couple of years (or more).
I'd also stick in a Composite or S-Video as sometimes these can be a life saver if your having problems configuring for Component or Digital.
Best regards
Joe
maxwan
where can i get a price on HDMI cable in the UK ?
I have ordered component cable from blue jeans cable in the USA
because UK prices came very expensive. I will ask them for a quote
Joe Fernand
AVForums Sponsor
maxwan
Plenty of places that supply Component cables at reasonable prices in the UK - I'm biased I think OUR prices are reasonable for the brands I supply.
I have lots of HDMI cables in stock so drop me a note and maybe our pricing on HDMI will meet your requirements :)
Best regards
Joe
maxwan
after reading about component cable and getting pushed towards belden cable, where would I start on what is quality HDMI cable and what is poor as well as looking at prices
Y
yan
Does anyone have any info on how good the high end HDMI cables are, is it worth going for a digital magic cable (£67 for 2m)or a wireworld cable(£200 ??) as opposed to the Molex cable(£22 for 2m).
Although based on what I have read so far about HDMI it does put me off spending loads of money on a high end cable. Although I suppose if I want to get the best out of my HDMI gear I need to get a decent cable.
Joe Fernand
AVForums Sponsor
yan
If you cant decide between Molex and BetterCables have both :)
Seriously though if you want one of each to try and then keep the one you like best please drop me a note.
Best regards
Joe
PS I've asked for a WireWorld Starlight5 cable to try it out but no stock in the UK at present (other than the ONE cable doing the rounds of the magazines).
F
friend
Does WireWorld Starlight5 cable make a difference ?
In other words does it worth tha money ?
Joe Fernand
AVForums Sponsor
friend
According to WireWorld it does :)
I've not seen any comparative reviews as yet and as per previous post I cant get a cable to test at present as the ONE cable that's in the UK is doing the publicity rounds.
Best regards
Joe
Y
yan
Joe I did PM you, but nonetheless I will take one of the better cables, what do I need to do from here? Incidentally which one do you use or do you not use your HDMI socket?
65-inch LG C1 Review coming soon to AVForums
