HDMI Cable
BluRayBilbo
This has probably been a thread that is posted over and over but I cant seem to find it.
Can any of you kind chaps recomend a good HDMI cable?
Thanks in advance! :cool:
joeprosho
hi i started trying to read up on a bit of cable info,
tbh i cant be arsed learning about all of this though its taken me forever to learn about what tv and stuff to get
for connecting a ps3 to an LG 42LH2000 its only 720, the distance is less than a metre will basically any od cable do?
it seems 1.3hdmi is more built for future HD releases so doesnt matter for my not high spec model
MarkTaylor
Short answer is 'yes' any non-faulty HDMI cable will handle what you need.
Dcolman
PS3 should have HDMI, AV, Component output, you can consider different ways to connect it to LG TV, different way should cost different... but a HDMI cable will do too.
