HDMI cable help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jamieaston1, Jun 14, 2008.
  1. jamieaston1
    jamieaston1
    Jun 14, 2008
    9
    I need to purchase a HDMI lead, so that sky HD can be viewed in another room of the house. The cable needs to be 15 meters long. My problem is that looking at the prices of the HDMI cables they vary a lot. Due to this please may you recommend a brand and the sort of money I should be spending on this cable?
  2. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    Not trying to be awkward but you really need to do a search of this forum for HDMI leads, there are hundreds of posts on this topic, including a lengthy debate on the merits of paying for an expensive one. You could start with this one:
    http://www.avforums.com/forums/showthread.php?t=761446
  3. derek500
    derek500
    Dec 23, 2007
    3,740
    103
    +497
    Can't you use component? I get a stunning HD picture on a second TV.
  4. jamieaston1
    jamieaston1
    Jun 14, 2008
    9
    What do you mean by a component?
  5. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    Derek's suggesting that instead of HDMI you use the component outputs from the Sky box. They are three phono-type outlets coloured red green and blue, and provide an analogue HD picture signal through wires similar to those you use to connect up your audio equipment. This might be an easier way to get good HD than a long HDMI cable. Remember though that they only carry image - for sound you'd also need a pair of phono cables.
  6. Mac User
    Mac User
    Sep 27, 2006
    4,523
    Norfolk
    +308
    That's if he's Sky HD box has component out. I've just had a Sky HD box swap out and my new box doesn't have the component connections :( where my old one did.. luckily I don't use component just HDMI
  7. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    That's interesting. I imagined they'd continue to use the old boxes refurbished for a good while before using the new ones for swaps.
  8. Unique Geeza
    Unique Geeza
    Jun 16, 2006
    312
    Near Gatwick Airport
    +12
    when you say about veiwing SKY HD in another room of your house.. do you also mean you want to see the SKY HD in the same room as your HD box at the same time ? all hdmi cables have been found to do the same job... expensive or inexpensive... they all carry a digital signal mate...
  9. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    While personally I agree with that, I suggested the OP do a search as there was still sufficient disagreement that he needed to read the threads and make his own mind up.
  10. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    What's the version number of the box? Component-less Thomson boxes shouldn't be 'in the wild' AFAIK.
  11. brighteyes
    brighteyes
    May 31, 2006
    100
    Somerset
    +15
    From what I have heard the new Pace boxes will not have component outputs, all to do with HSCP compliance for which you need an HDMI cable - this is to stop copying of programmes.
    Also there is supposed to be a Samsung box in testing but I'm not sure if this has been comfimed.
    Holy_Pilgrim, Do you have a make/model number for this new box?
  12. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    The new Samsung and Pace boxes DO NOT have componenet, no if's, no buts, We can view box pictures on out knowledge base at work.
  13. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    People on here have had them
  14. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    yes, and we were told that they'd been released early and to pass custoemrs with these boxes to our higher tech dept. not sure what happened after that or if the boxes were replaced or what but only that they'd been released ahead of time and shouldn't have been.
