HDMI Cable Help And Recommendation
Discussion in 'General TV Discussions Forum' started by gavbrad, Feb 25, 2018.
  1. gavbrad
    gavbrad
    Dec 2, 2009
    12
    Hey,
    I'm a bit out of the loop with cables at the moment (the last TV I purchased was in 09). Basically I need to run a HDMI cable the length of a new room and under a carpet to keep it concealed. So the cable needs to do the following:
    Be at least 10 meters long
    Be able to do all of the 4K HDR etc (I don't want to pull up the carpet when I upgrade the TV)
    If possible flat so it's not noticeable under the carpet.
    What would anyone recommend?
    Or am I living in a magical land and this kind of cable doesn't exist then what cable longer than 10 meters would you guys recommend?
    Thanks in advance for any advice
