Question Hdmi cable for HDR
Discussion in 'Cables & Switches' started by Monkeyboylee, Apr 28, 2016.
  1. Monkeyboylee
    Monkeyboylee
    May 4, 2005
    707
    Harrogate
    +21
    What bandwidth will a hdmi cable need for Hdr, or will current high speed 10.2gb/s still be ok?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    A High Speed or one of the new Premium High Speed cables is what you require - any claims of particular speeds are all based on non verifiable tests/in house testing with no known references.
    http://www.hdmi.org/manufacturer/premiumcable/Premium_HDMI_Cable_Certification_Program.aspx
    Cable length is, as ever with HDMI, the bigger problem - once you get past 4 or 5m it is very difficult to predict what will/won't work, for longer run lengths we are using Fibre HDMI.
    Always try with your existing cable(s) before you assume you need to purchase anything new.
    Joe
