HDMI cable choice
Discussion in 'Cables & Switches' started by mgoode180566, May 5, 2007.
  1. mgoode180566
    mgoode180566
    Feb 1, 2007
    3
    I am looking for a cable to connect my 5960 to LCD tv. I have seen some on ebay at a fiver. How do they compare to say a Belki at £40 for example ? Any advice appreciated, it would seem there is a huge price diff so would like an idea of performance.
  2. bumpymark
    bumpymark
    Mar 15, 2007
    363
    hull
    +88
    hi there
    i recently purchased a hitachi plasma screen to finish my home cinema setup and im currently using a hdmi cable i purchased from a local shop called boyes of which i paid £12 for! the length of this cable is 3mtrs and it appears just as well built as a major brand-indeed when i compared prices at a national retailer they wanted upwards of £110 for a 1 mtre hdmi cable so my advice is try a "cheapo cable" off ebay in fact you may find that most of these cables are made in the same factory and are just packaged for the different retailers-its called badge engineering
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,134
    Bristol
    +9,879
    Over short lengths a £5 cable should be just as good as a £50, after all digital is 1's and 0's so either they get through or they dont.
  4. Ron240
    Ron240
    Jan 3, 2002
    3,630
    Kirkcaldy (but i'm not a Fifer)
    +472
    That must have been from the....I Saw You Coming shop :rotfl:
    It can currently be seen every Monday night on BBC1.
    Seriously though,i have never seen even the very expensive HDMI cables cost anything like this much for a 1m length. A person would need to completely brainwashed to pay that amount. :eek:
  5. Freaky
    Freaky
    Oct 21, 2005
    Another Planet
    ive ALWAYS wondered that about cables, and scart leads etc, DO the more expensive ones REALLY make any diff at all.
    Ive seen scart cables at £80 to £100, would these actually be any better than say a £10 one.
    I need a very short HDMI cable myself soon for virgin media cable box, and this question was in my mind also.
  6. Ron240
    Ron240
    Jan 3, 2002
    3,630
    +472
    Its always worth spending more on a good quality Scart cable,because it can most definitely make a difference. Personally,i have always used QED Sqart cables,because i consider them to be one of the best on the market.
    You dont have to spend a fortune - even their top cable,the Silver Reference,can be bought for around £60 in a 3m length.
    HDMI is different - anything 3m or under....in most cases,all things being equal,you should be perfectly ok with a cheap cable(ie. £10 or less for 1m),and will not see any advantage in spending much more. :)
    But,there are always exceptions to every rule.
  7. kdog
    kdog
    Mar 6, 2006
    360
    Ayrshire
    +61
    Hi Ron240, :hiya:
    What about over 3m? I'm looking to purchase a HDMi cable between 8 -10m depending on whats available. What would you recommend?
    Cheers.
  8. Ron240
    Ron240
    Jan 3, 2002
    3,630
    +472
    I would not be able to recommend any cable specifically,but for an HDMI cable of this length,it is definitely worth paying extra for a good quality brand name. :)
    At his length though....will not be cheap.
