HDMi cable advice
Discussion in 'Cables & Switches' started by LouiseUK, Sep 11, 2007.
  1. LouiseUK
    LouiseUK
    Newbie alert ;)
    I've got the following being delivered this week and I was just wondering if two HDMi cables are sufficient? Eg: TV to DVD and then DVD to AV? Is this all I'll need?
    TV: Sony KDL-40D3000
    Home Cinema System: Sony HT-SF1100
    DVD Recorder: Sony RDR-HXD970B
    Many thanks in advance!
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,724
    The Borders
    +3,513
    Hello LouiseUK
    Any links to the specs of the two Sony items?
    Joe
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,402
    2
    In a secret location with Jennifer Lawrence
    +11,712
    For the Home Cinema System do you mean the HT-SF1100?
    If so, you would need 2 HDMI cables.
    1 from DVD player to the all in one, and then one from the all in one to the TV.
  4. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    If its the HT-SF1100 you will also need an optical cable to go from your DVD player to the HTSF1100, as the HTSF1100 does not do audio over HDMI.
    Taken from Sony.co.uk
  5. LouiseUK
    LouiseUK
    Oops, I did mean the HT-SF1100!
    Many thanks guys :D
  6. LouiseUK
    LouiseUK
    I'm back again!
    So, I can't for the life of me get this right *sigh*
    At the moment I've got:
    TV to DVD via HDMi
    DVD to AV via digital COAX
    Have I got it completely wrong? Is there a better way?!
    Please help :)
  7. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    Yes that would be right.
    The only better way than Digital Coax would be sound through HDMI which your HTSF1100 can't do.
    You could try an Optical cable if there is a problem with the Coax but it basically is the exact same type of connection.
  8. LouiseUK
    LouiseUK
    Phew, that's a relief!
    Thanks Anthony :D
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,724
    The Borders
    +3,513
    Hello LouiseUK
    You have a few options - all will work though the functionality will vary depending on how you choose to connect things up.
    Your AV Receiver (HT-SF1100) can act as a 2x1 HDMI switch - though this requires that the HT-SF1100 is always active.
    You may prefer to wire your HDMI equipped Sources (up to three Sources) Direct to the HDMI Inputs on the TV as then you can view and listen to the Sources (using the TV speakers) without the AV Receiver always having to be on.
    Option 01.
    RDR-HXD970B
    Digital Video - HDMI>HDMI to HT-SF1100
    Digital 5.1 Audio - RCA>RCA - to HT-SF1100
    HT-SF1100
    Digital Video - HDMI>HDMI to KDL-40D3000
    Option 02.
    RDR-HXD970B
    Digital Video + Stereo audio - HDMI>HDMI to KDL-40D3000
    Joe
