HDMI Audio
Discussion in 'Cables & Switches' started by emptycup, Feb 8, 2009.
  1. emptycup
    emptycup
    Oct 13, 2006
    290
    19
    +17
    Hi all,
    Hope this is quite a simple question to answer......:thumbsup:
    Is there any advantage to using a seperate optical audio cable rather than using HDMI for viseo and audio? I am thinking of buying a new AV receiver but I currently use 3 optical outs and the AV receiver I am thinking of only has 2.
    However, my current AV Receiver doesn't have any HDMI. If audio is fine through HDMI I won't need to use 2 out of the 3 optical leads that I currently use.
    Cheers in advance folks!!
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,759
    The Borders
    +3,523
    Hello emptycup
    HDMI is a mixed bag in terms of audio support.
    HDMI.org have made it possible for a Source device to Output pretty much all know Consumer audio formats (inc. the latest uncompressed HD audio codecs) over HDMI.
    Whatever you Output from your Source device via HDMI must also be supported via HDMI on the Input of your AV Amp, Display etc.
    Not all Source devices output audio via HDMI - those that do don't all support multi channel (compressed or uncompressed) so you cant easily generalise on what will be best for you without knowing what devices your system will include.
    SKY HD for example Outputs 2.0 LPCM (Digital Stereo) via HDMI and only offers a multi channel (DD 5.1) Output via Optical.
    Joe
  3. emptycup
    emptycup
    Oct 13, 2006
    290
    19
    +17
    Thanks for the info. My plan is indeed to install SKY HD - I didn't know it would still require an optical cable. Do you know if the PS3 will deliver suround sound/HD audio through HDMI?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,759
    The Borders
    +3,523
    The PS3 will deliver 7.1/5.1 LPCM over HDMI - assuming your Amp is compatible with those signals!
    Joe
  5. emptycup
    emptycup
    Oct 13, 2006
    290
    19
    +17
    Thanks for the advice matey! Will make sure of that ;)
    I knew I could rely on this place :):thumbsup::thumbsup:
