Question HDMI ARC not working with Sony WD75
Discussion in 'Sony TVs Forum' started by Van Dam, Dec 20, 2017.
Tags:
  1. Van Dam
    Van Dam
    Dec 14, 2005
    6,347
    4
    137
    London Terminals/ Manchester Stations
    +800
    On my 32WD756 I am unable get audio to a Sony wireless speaker (via HDMI ARC). I can't tell if there is an issue with the TV or speaker. SongPal app is rubbish. Any helpful suggestions?
  2. Dodgexander
    Dodgexander
    May 29, 2007
    14,931
    +4,344
    Its a long shot but are you using the latest firmware? Firmware update to v8.211 | Sony UK
    Also, have you tried a factor reset just to be sure?
    Finally, some cables can give mixed results, its probably worth trying another just in case.
    Its a question of process of elimination when it comes to problems like this but HDMI CEC is renowned for being flaky, sometimes things just don't work, you should definitely get in touch with Sony.
  3. Van Dam
    Van Dam
    Dec 14, 2005
    6,347
    4
    137
    +800
    Thanks for the tips. Yes, I have the latest firmware for both units. I've also done a factory reset for the TV but not the speaker so I shall try and do that when I have a chance. I will try a different cable too. Thanks again.
  4. Van Dam
    Van Dam
    Dec 14, 2005
    6,347
    4
    137
    +800
    I have tried all possibilities and have verified that the speaker was faulty. The HDMI indicator lights up on the speaker (SRS-ZR5) as it should but there is no audio. Back to using my trusty SRS-X5 (via analogue 3.5mm connection). :(
