HDMI advice for a HDMI newby
Voy06
Okay so i've just bought a Sony DVP-NS76H dvd player which I will connect to my LCD TV via HDMI.
My questions are:
1) Will you gain any real difference in picture quality between expensive HDMI leads and not so expensive HDMI leads?
2) What brands/makes of HDMI leads should I be looking out for?
3) For a HDMI connection between the above dvd player and an LCD TV what sort of price range should I be looking at for a good quality HDMI lead?
The lead doesn't need too be any longer than 2 metres.
Thanks guys for any advice.
Chris Muriel
1) Current opinion is that for shorter cable lengths (less than 10 feet or 5 metres depending on who you talk to) a cheap cable or one supplied with a TV, DVD player or STB should be fine.
Therefore 2) and 3) shouldn't really enter into the equation in your case.
Chris Muriel, Manchester
