HDMI acceptable?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Les E, Jan 25, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    936
    St. Helens
    +14
    I wasn't too sure which forum to put this in as it covers about three, but I 've landed here!
    Anyway, I've been checking the Denon 2910, Screenplay 5700 and the Lindy HDMI lead on whether they are all compatible with HDCP.
    They all seem compatible for output, however the specs for the player and the PJ state it will play when a source material thru a HDCP lead connected via DVI.
    Can someone clarify that this also covers HDMI leads, as it doesn't state it on the full equipment specs but they do accept both signals.
    Anyone help to clear this up?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,582
    3
    North Yorkshire
    +269
    All DVI and HDMI cables are capable of passing HDCP encryption - it's the connector transmitter and receiver chips that need to be compliant. Btw, all HDMI connectors are compatible by default. Hope this helps.
    Steve
  3. Les E
    Les E
    Oct 5, 2004
    936
    St. Helens
    +14
    That's good news...thanks for the help!!
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    HDCP is purely a software specification of the data that is sent between two devices, thus it has no relevance to a cable carrying the electronic signals conveying that data and so you'd not see it mentioned in a cable's spec.
